6ril
Dec 20, 2014Aspirant
RN 104 poor performance -> unusable
Hi, I have a RN 104 with 3 2TB disks in RAID5. The performance I'm talking about is simply FOLDER ACCESS!! some folders can be accessed normaly, and others are just unbearable slow, like 7 minu...
vandermerwe
Dec 20, 2014Master
Well the 100 series processors aren't that fast and antivirus even slows down the readynas devices with more capable processors.
COW is enabled/ disabled on a share by share basis, in share settings.
The smart stats can be seen of you click on the volume settings icon on the volume tab, select settings then disks.
Alternatively hover over the green dot next to each disk in the performance tab.
You are looking for errors.
