6ril
Dec 20, 2014Aspirant
RN 104 poor performance -> unusable
Hi, I have a RN 104 with 3 2TB disks in RAID5. The performance I'm talking about is simply FOLDER ACCESS!! some folders can be accessed normaly, and others are just unbearable slow, like 7 minu...
vandermerwe
Dec 20, 2014Master
So the problem with failure to shut down is still there?
Have you upgraded to 6.2.1? Does the nas reboot properly?
If you shutdown using the power button, does it also hang?
You should try an OS reinstall using the boot menu:
http://kb.netgear.com/app/answers/detai ... -or-314%3F
Do you have a backup of your data?
It is the weekend before Christmas,I think it is a bit much to expect Netgear to be patrolling the forums right now.
