tbachne
Oct 08, 2025Aspirant
RN 10400-100 EUS Volume Not Accessible
Sehr geerhrte Damen und Herren - ich besitze ein ReadyNas 104, was bislang tadellos funktioniert hat. Da ich im Urlaub war, habe ich das System heruntergefahren. Nachdem ich nach dem Urlaub das S...
Oct 08, 2025Guru - Experienced User
tbachne wrote:Here I get a message telling me to remove the inactive volumes.
First of all, don't do that.
tbachne wrote:What can I do to restore the volume and access the data?
Sorting out the next steps requires analyzing the full log zip (downloaded from logs page on the admin web ui).
There is a lot of info in there - if you need help, I can review them for you. Put the full zip into cloud storage and send me a Private Message (PM) with a link, using the envelope icon in the upper right of the forum page. Make sure the permissions allow anyone with the link to download.
tbachne wrote:I shut down the system
Do you recall how you shut it down? (In particular, if you did a graceful shutdown, or whether you just turned off the power)?
