Waynec2
Sep 12, 2026Aspirant
RN-524X Power Supply Part Suppliers
My RN-524x AC Adapter doesn't provide 12V to the NAS. The adapter indicates P/N:332-10934-01, Model:2ABU120F, Input: 100-240V ~50/60Hz, 2.0A MAX, Output + 12V--10A. The pin diagram shows Pin-1 12V,...
- Sep 13, 2026
When looking at power supplies with the 4-pin connector, be aware that not all use the same pin-out. All Synology models that use a 4-pin power supply have the same pin-out, and you may have better luck searching for that. There are several models available on Amazon, though not all are 10A.
StephenB​ obviously intended to say to check that it's rated at at least 10A, not 2A. Be especially warry if the seller's photos "conveniently" hide the power rating in the photos.
kmsauds
Sep 13, 2026Initiate
Search for replacement adapters using the exact part number 332-10934-01 or the power rating (12V, 10A with a 4-pin DIN connector matching your pinout) on specialized server/NAS parts supplier websites or eBay.
