redcons
Nov 20, 2015Aspirant
RN102 dropbox sync problem
Hi I I am wondering if someon can help me with an issue I have with an RN10200 I have installed OS6.4 so it is up to date I have configured my backup to dropbox and entered the credentials and selec...
JennC
Nov 21, 2015NETGEAR Employee Retired
Hello redcons,
Welcome to the community!
Have you checked which files are not being copied? Maybe you can try copying them to another share of the NAS then sync that share with DropBox to see if same problem, if same then there must be something on those files.
- PadgJan 31, 2016Aspirant
Hi, I am also having syncing issues with dropbox.
Reading on the Dropbox website it mentions file incompatibilites and Linux software has a 10,000 file sync limit which can be changed. Could there be anything similar happening with the Netgear Dropbox app?
Thanks
- BrianL2Jan 31, 2016NETGEAR Employee Retired
Hi Padg,
I hope you could tell us more about your sync problem with the built-in Dropbox feature of your ReadyNAS. Also, mention which Firmware is running in your system.
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
