MavZ3
Aug 02, 2016Aspirant
RN102 not connecting to network
I have a RN102, I have followed the set up instructions but it does not get and IP address from my router. It is not shown as an attached device. After booting the power button is on and the act bo...
- Aug 03, 2016
Solved, couple of minutes. All working now after USB restore.
http://kb.netgear.com/app/answers/detail/a_id/29952
Thanks
MavZ3
Sorry I meant to say RAIDir does not find it either.
I have a DUO v2 on the same switch which it does find and is working fine. I have tried with that turned off also. No joy.
Thanks
Aug 02, 2016Guru - Experienced User
I think the fastest option is to use your 90 support.
I am guessing that there is a hardware failure in the chassis.
