jpport123
Feb 19, 2018Aspirant
RN102 power led keeps blinking after firmware update
After bringing the V1.3.0.20_10.1.1 down and installing it, during the restart, the power light began flashing and I could no longer get the device to load. Is there a way to restore the firmware or...
Feb 23, 2018Guru - Experienced User
The ReadyNAS RN102 uses 6.x firmware versions, not V1.3.0.20_10.1.1
Are you having this issue with your Nighthawk Router?
jpport123
Feb 23, 2018Aspirant
That is correct - it was the nighthawk router. After the update, the power light went red and continually flashed even after discnnecting the power and plugging it back in.
