sanjeewakuku
Dec 14, 2017Aspirant
RN10200 not visible
hi, power LED on. strat up blink few second only. network port green color LED blinking. but no ip or discover to RAIDar how to pix that
- Dec 27, 2017
i have using usbrecovery.v2.0.T14.support. USB flash and problem solved
sanjeewakuku
Dec 15, 2017Aspirant
msq wrote:If that is the device you're trying to set up for the first time - you can try to reset it.
Additionally - is your router running dhcp? Or device is booted with its default IP address but your own IP settings are not allowing to see your ReadyNAS?
no. alredy running correctly. one time upgrade and will never geting up. maybe 1 yrar later that happend. i think somthing wrong with OS. Yes. my router running DHCP. i have
1.Power off your storage system.
2.Using a straightened paper clip, press and hold the Reset button.
3.Press the Power button.
The system powers on.
4.Continue to press the Reset button until the Power button LED, USB and backup status LED, disk 1 LED, and disk 2 LED light.
5.Press the Backup button to scroll through boot mode options.
Factory default.
same result. divice not visible for me. :(
msq
Dec 15, 2017Apprentice
Ok - factory default already erased all data on the disk....
You can try OS reinstall - this is next step after 'factory default'.
- sanjeewakukuDec 15, 2017Aspirant
msq wrote:Ok - factory default already erased all data on the disk....
power off and press reset button and plug to power after slelct boot menu OS reinstall
Disk 2 LED lights. and press reset button.result> power LED blink few seconds and LED stable.
not visibel yet. :(
- msqDec 15, 2017Apprentice
Both - factory reset and os reinstall can take 5 to 15 minutes. Additionally:
Factory default. Initiates a short disk test that takes approximately 5 minutes. After the disk test, a 10-minute time-out period begins, during which all LEDs blink simultaneously.
Please - give it few more minutes.
msq wrote:Both - factory reset and os reinstall can take 5 to 15 minutes. Additionally:
ok now again OS reinstall
select Disk 2 LED light and reset button.power LED blink few second and continues LED on now. im waiting 15 min. and i will post reply whats happend.
- sanjeewakukuDec 16, 2017Aspirant
not change. same issue. :( :( RN10200 not visible
- JohnCM_SDec 21, 2017NETGEAR Employee Retired
Hi sanjeewakuku,
Do you have RAIDar installed on a computer? If yes, does RAIDar detect the NAS even if there is no disk inside it?
JohnCM_S
NETGEAR Community Team - JohnCM_SDec 26, 2017NETGEAR Employee Retired
Hi sanjeewakuku,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,JohnCM_S
NETGEAR Community Team - sanjeewakukuDec 27, 2017Aspirant
