sanjeewakuku
Dec 13, 2017Aspirant
RN10200 not visible
hi, power LED on. strat up blink few second only. network port green color LED blinking. but no ip or discover to RAIDar how to pix that
- Dec 26, 2017
i have using usbrecovery.v2.0.T14.support. USB flash and problem solved
JohnCM_S
Dec 21, 2017NETGEAR Employee Retired
Hi sanjeewakuku,
Do you have RAIDar installed on a computer? If yes, does RAIDar detect the NAS even if there is no disk inside it?
JohnCM_S
NETGEAR Community Team
JohnCM_S
Dec 26, 2017NETGEAR Employee Retired
Hi sanjeewakuku,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JohnCM_S
- sanjeewakukuDec 26, 2017Aspirant
