dloca68
Jun 05, 2019Aspirant
RN10200 "shares" not visible in web interface
Hello, I no longer see the "shares" when I log in as admin from the web interface, I only see "home" but before I had 5 shares with relative permissions for users and groups. However the shares a...
Jun 05, 2019Guru - Experienced User
dloca68 wrote:
how can i solve?because if I don't see the shares I can no longer make changes to their configuration.
My first suggestion is to make (or update) your backup of your files. Something is definitely wrong with the NAS, and your data is particularly at risk.
dloca68 wrote:I no longer see the "shares" when I log in as admin from the web interface, I only see "home"
This is when browsing to https://nas-ip-address/admin ?
Are you seeing any other errors (for instance, warnings of a full root partition)?
- dloca68Jun 05, 2019Aspirant
Hi Stephen,
There aren't any error in web interfacce.
Yes i'm browsing to https://nas-ip-address/adminThanks
Dario- StephenBJun 06, 2019Guru - Experienced User
Well, backing up the data is the first priority.
Also, try to download the log zip file - there likely are some clues in there. You can send a link to them in a private message to JohnCM_S or Marc_V and ask them to analyze the logs for you. But don't post the link publicly. You use the envelope icon in the upper right of the forum page to send a PM.
- dloca68Jun 06, 2019Aspirant
Yes of course, i'm doing backup now and also I'll check it.
after that I download the log zip file and send as private message
Thanks again
Dario
