hexnut4
Nov 23, 2017Aspirant
RN10200 slot 2 not recognizing disks?
My ReadNAS 102 has been running fine for some time with a matched set of 250GB drives in an X-Raid configuration. I wanted to expand capacity so I purchased two WD Red 2TB drives to replace the old ...
hexnut4
Nov 25, 2017Aspirant
A factory reset with a new WD Red drive in slot 1 and slot 2 empty worked. Powered down the unit and moved the drive to slot 2, leaving slot 1 empty. Powered up and after the initial fast flash of the power LED the system went into the steady flashing power LED mode with the slot 2 LED off and no other LEDs lit.
It sounds like it might be time to start the return authorization process...
-Steve
