NoMfgSupport
Dec 04, 2016Aspirant
RN10223D really dead!
So, my ReadyNas is dead. It does not respond to any commands. I have removed the harddrives and removed all partitions (on a Windows 10). I have used a the USB Recovery Tool to flash new firmware (...
- Dec 05, 2016
Your system must have been running 6.2.5 or earlier before you did USB Boot Recovery.
Systems running 6.2.5 or earlier cannot be directly upgraded to 6.6.0.
It should now be fixed.
NoMfgSupport
I should perhaps mention that I have no disk LED's whatsoever and that RAIDAR does not pickup my NAS.
When trying to do a disk test, the system just performs as usual, Power LED flashes for a few seconds and then goes to solid.
The disks spin up OK so I would think that they are OK (since they were also manageable in Windows 10).
/Lars
- mdgm-ntgrDec 04, 2016NETGEAR Employee Retired
Which firmware were you running before attempting USB Boot Recovery?
- NoMfgSupportDec 04, 2016Aspirant
Hi Mdgm,
That is a question that I do not have the answer to.
It was first setup by a colleague of mine and it has done its job for a while.
I did read that you should not downgrade by using USB so I took the latest avaiable.
Nothing changed by trying this. It has been reacting the same ever since I got it in my hands.
It was upgraded to the latest available firmware at the time of purchase.
/Lars
- mdgm-ntgrDec 05, 2016NETGEAR Employee Retired
