NoMfgSupport
Dec 04, 2016Aspirant
RN10223D really dead!
So, my ReadyNas is dead. It does not respond to any commands. I have removed the harddrives and removed all partitions (on a Windows 10). I have used a the USB Recovery Tool to flash new firmware (...
- Dec 05, 2016
Your system must have been running 6.2.5 or earlier before you did USB Boot Recovery.
Systems running 6.2.5 or earlier cannot be directly upgraded to 6.6.0.
It should now be fixed.
NoMfgSupport
Hi Mdgm,
That is a question that I do not have the answer to.
It was first setup by a colleague of mine and it has done its job for a while.
I did read that you should not downgrade by using USB so I took the latest avaiable.
Nothing changed by trying this. It has been reacting the same ever since I got it in my hands.
It was upgraded to the latest available firmware at the time of purchase.
/Lars
mdgm-ntgr
Dec 05, 2016NETGEAR Employee Retired
- NoMfgSupportDec 05, 2016Aspirant
Thank you for a very quick respons to my problem.
You are probably right regarding the previous firmware version altough I cannot say for sure.
Best regards,
Lars
