Retired_Member
Jan 14, 2016RN104 - Inaccessible Intermittently
Hi all, After i updated the firmware of my RN104, i have intermittent time-outs. It will work fine for about 10-20 minutes, then i will have a 2 minute window (approx) where i cannot access the N...
Retired_Member
Jan 14, 2016Right after this post i found this one: https://community.netgear.com/t5/Using-your-ReadyNAS/rn104-updated-to-6-4-0-and-possible-solution-to-random-lock-ups/m-p/993214#M95432
Will try that to see if it helps.
- JennCJan 14, 2016NETGEAR Employee Retired
Hello yveZ79,
In case you get the same problem, please post the firmware version you have on the NAS, if you already have disabled AntiVirus and if you have enabled any other apps in the admin page of the NAS.
Welcome to the community!
- Retired_MemberJan 14, 2016
Hi JennC, Thank you :)
I updated to 6.41. The thing is, when i want to access the admin page, it says it is version 6.40 but when logged in, it says version 6.41
I deleted all snapshots and deleted all schedules for them. Also, all apps are turned off except transmission and it is not having and files running/downloading.
Also, my FTP transfer rate as dropped from an average of 40MB/s to +/-8MB/s....so something is really wrong. I am assuming it is not hardware as it started right after i updated from 6.40 to 6.41, but i cannot rule anything out yet.Thanks!
Yves- mdgm-ntgrJan 15, 2016NETGEAR Employee Retired
Perhaps try ReadyNASOS 6.4.2-T72 (Beta 2)
Can you send in your logs (see the Sending Logs link in my sig)?
