jaholstein
Jan 27, 2016Guide
RN104 6.4.1 Anti-Virus Plus Live Scan [red-dot] disabled
I have read all the relavant discussions and cannot find a solution. Saw something about a "faint checkbox" ... not sure, but I think my setup is correct I just updated to 6.4.1 (x86) running Wi...
- Jan 27, 2016
jaholstein wrote:
I just updated to 6.4.1 (x86) running Win 7 sp3 with all current updates and drivers.
Is this an indication of something wrong?
It might be. But you should be keeping the AntiVirus service disabled on 6.4.1 and above anyway - it creates a huge performance problem, and Netgear has recommended turning it off until they have a fix.
Jan 27, 2016Guru - Experienced User
- prosenbaFeb 26, 2016Aspirant
Now that 6.4.2 you would expect the anti virus issue to be fixed now, It's totally not acceptible to run a nas and not be able to scan the drive for viruses.
- StephenBFeb 26, 2016Guru - Experienced User
prosenba wrote:
Now that 6.4.2 you would expect the anti virus issue to be fixed now...
@There is a fix being tested. PM mdgm if you want to try it.
- jaholsteinFeb 27, 2016Guide
How is Netgear going to ADVISE all of the RN users that the Antivirus problem has been fixed?
I'm certainly NOT going to check this forum weekly - but I do agree that the present situation is totally unacceptable.
