gregwhite886
Jun 01, 2017Tutor
RN104 6.7.4 update causing problems on 2 x RN104
We have updated 6 ReadyNas 104 devices today with firmware 6.7.4 to patch the recent documented Samba vulnerability and 2 unts are now not functionning. 1 is stuck at 99% booting an we are unable to ...
akustikbuero
Jun 06, 2017Star
We have the same problems with our ReadyNAS 2120v2
Conection-Losses of all Shares (SMB und RSYNC) after 1 or 2 hours of boot. I am remembered on Feb. 2016 after a firmware-update and it took 2 mounths to fix it and I spend weeks of unpaid administation-hours....
Now I'll rip that ReadyNAS out of the server-shelf, get the harddrives out and replace it which something "NOT-Netgear" and problem solved!
- gregwhite886Jun 06, 2017Tutor
Yeah frustrating wasting valuable man hours wrestling with this. However, i think i may have just found the issue. When i first set up the iSCSI LUN's, they were unauthenticated with CHAP. Shortly before the update, i added CHAP authentication to them all and reconnected my hosts. After the upgrade, i started having the issues where all the LUN's went 'Reconnecting' and the NAS box was hanging. I read somewhere that another user had an issue where if any unathenticated hosts tried to connect to a LUN, it would crash the iSCSI service on the NAS. I have since turned off CHAP authentication on the LUNs to test and so far, everything has stayed connected! Not ideal, but for now it is stable and controlled by firewall rules to access.
Let's hope it stays that way else i agree with you...... i'm grabbing a bat as wasted many hours.
- mdgm-ntgrJun 06, 2017NETGEAR Employee Retired
So the problems are all resolved by disabling CHAP?
If not I can have a look at your system if you like.
If you're still having issues you could start by downloading the logs using RAIDar then sending them in (see the Sending Logs link in my sig)
- akustikbueroJun 07, 2017Star
No I can't sent you any logs, because I dit an Factory Reset again. I have not time and no drive to find out by my self how to disable CHAP and read hours ans hours form some maybe-sorted-Problems.
I would like to know how to disable Netgear-Firmware-Updates in the future?
