Anonymous
Aug 13, 2019RN104 can not accesssed
Hello. Booting from 104 USB Failed! It is now indicated as. BOOTMENU could not be accessed by starting with the reset button pressed. Also, I used USB Recovery and the power was turned off after ...
Marc_V
Aug 13, 2019NETGEAR Employee Retired
Retired_Member
Welcome to the Community!
The NAS turning off after initiating USB recovery means the recovery was successful.
Have you tried running the USB Recovery again using a different USB stick? Have you tried updating the Firmware before this happened?
Please try to download RAIDar as well and check on the Status after USB recovery attempt.
If the same routine happened but still the NAS is not booting, you may want to contact Support at this time and have it checked as it may need RMA.
HTH
Regards
- StephenBAug 13, 2019Guru - Experienced User
This would be a warranty return, so check the warranty status before contacting support.
The warranty is three years for the original purchase.
- AnonymousAug 17, 2019
Thank you for your reply.
I tried another USB stick as well, and the results were the same.
Also, there was no attempt to update the firmware before this symptom appeared.
What's puzzling is that even if I didn't press the backup button, the USB recovery started by inserting the USB stick.
Last but not least, I bought it more than 6 years ago, so support is broken.
Could you tell me what I should do next?
