Jeff_D
Feb 15, 2016Aspirant
RN104 crashed with kernal seg-fault or ???
HI, My RN104 stopped communicating and after I verified that it was ON but not answering I looked at the front display and all the unit said was do_exit+8d8. It was non-responsive to the power butto...
Mar 29, 2016Guru - Experienced User
I suggest sending in your logs ( http://kb.netgear.com/app/answers/detail/a_id/21543/~/how-do-i-send-all-logs-to-readynas-community-moderators%3F )
Alos PM kohdee and mdgm-ntgr, asking if they can take look (include a link to this thread and the subject line of your log email).
HelloGear
Mar 29, 2016Aspirant
A log file sent by email.
Thank you.
- mdgm-ntgrMar 30, 2016NETGEAR Employee Retired
Please try ReadyNASOS 6.5.0-T338 (Beta 2)
Also the snapshots on your system have not been upgraded so you should do:
# touch /.force_snapshots_upgrade# systemctl restart readynasd
to force the upgrade.- HelloGearMar 30, 2016Aspirant
I did both you mentioned above. However, situation seems to remain the same.
This time, the error message shown on the front display in shutting down is "do_exit+8d0", not "do_exit+8d8".
Should I send the log file again?- mdgm-ntgrMar 30, 2016NETGEAR Employee Retired
Was this a beta 104 unit?
