XAffi
Nov 05, 2021Aspirant
RN104 degraded, but no prorgess
Hi all. I am using my RN104 as a backup device sonce a very, very long time w/o any issues... Cool thing, not high performance, but good it works :-). I changed in my RN104 one of the 4 harddriv...
- Nov 06, 2021
I agree it doesn't look like it's expanding. First, make sure a 4th partition was created: fdisk -l /dev/sdd. You can also compare the size of the 4th partition to another drive's: fdisk -l /dev/sdc. If the partition is there and the right size, then the following should add it or give you an error message as to why it won't: mdadm /dev/md127 --add /dev/sdd4 --verbose.
If the partition isn't there, don't try to use fdisk to create it, it'll refuse to start it in the right place. I recommend you install and use parted for that.
XAffi
Nov 06, 2021Aspirant
Hi Stephan.
Thanks for your reply.
1. "SMR-Drives"--- I have them since almost 2 years now and yes, I am in the progress of replacing them step-by-step - the one I replaced was also an "SMR".
2. Is resync really running? Usually I see it in the /proc/mdstat. Any proposal where I can see if resync is running if it is not shown on the readynas itself, the web-interface or in the /proc/mdstat file?
Sandshark
Nov 06, 2021Sensei
- XAffiNov 06, 2021Aspirant
Hi Sandshark,
Thanks.. Meaning you assumed that due to whatever reason resync has not started by itself...
I have checked ans seen that all partitions are available, size matches as well...
I will follow closely...but it seems it is working...
fdisk -l /dev/sdd
Disk /dev/sdd: 7.3 TiB, 8001563222016 bytes, 15628053168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: E93A4BDA-2E80-4CE4-9C98-3E82A6477A2FDevice Start End Sectors Size Type
/dev/sdd1 64 8388671 8388608 4G Linux RAID
/dev/sdd2 8388672 9437247 1048576 512M Linux RAID
/dev/sdd3 9437248 7814037119 7804599872 3.6T Linux RAID
/dev/sdd4 7814037120 11721045119 3907008000 1.8T Linux RAIDfdisk -l /dev/sdc
Disk /dev/sdc: 5.5 TiB, 6001175126016 bytes, 11721045168 sectors
Disklabel type: gpt
Disk identifier: 328949D9-CF99-4854-BAA8-3FD7BCFE4E4CDevice Start End Sectors Size Type
/dev/sdc1 64 8388671 8388608 4G Linux RAID
/dev/sdc2 8388672 9437247 1048576 512M Linux RAID
/dev/sdc3 9437248 7814037119 7804599872 3.6T Linux RAID
/dev/sdc4 7814037120 11721045119 3907008000 1.8T Linux RAIDroot@Saturn:~# mdadm /dev/md127 --add /dev/sdd4 --verbose
mdadm: added /dev/sdd4cat /proc/mdstat
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md126 : active raid5 sda3[5] sdc3[3] sdd3[6] sdb3[4]
11706503424 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]md127 : active raid5 sdd4[4] sdc4[1] sda4[3] sdb4[2]
5860115712 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/3] [_UUU]
[>....................] recovery = 0.0% (647904/1953371904) finish=5449.9min speed=5971K/secmd1 : active raid10 sda2[0] sdd2[3] sdc2[2] sdb2[1]
1044480 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU]md0 : active raid1 sda1[5] sdc1[3] sdd1[6] sdb1[4]
4190208 blocks super 1.2 [4/4] [UUUU]unused devices: <none>
And finally:
- SandsharkNov 06, 2021Sensei
It was clear from the mdstat that the partition never got added to the volume, which would have then started the re-sync. The only question was why, and we still don't know. But I agree that manually doing so seems to have done the trick. But keep a lookout in case it fails somewhere along the way.
For whatever reason, the ReadyNASOS seems to increase the number of drives in an array before it adds a device to fill the empty slot. It is much more common to first add the device (so it becomes a spare), then change the number of devices (which will automatially start integrating the spare into the RAID).
Sandshark, I will follow, but for the time being things are running now as expected... Thanks again. Honnestly the RN104 is already a liittle bit older, and I am happy adding an 8TB drive is working at all... Latest next week resync shall be done.
