jameaghe
Dec 08, 2014Aspirant
RN104 ERR: Could not mount boot flash #24323690
The other day I tried an upgrade on my RN104 through the web interface. Apparently it failed and now the LCD on the front says, "ERR: Could not mount boot flash" every time I try to boot it. I've d...
Dec 08, 2014Guru - Experienced User
If you wanted to try a fresh install with your 320GB disk you should have unformatted it, not formatted it as NTFS. There are two common ways to unformat: (a) delete all partitions with windows disk manager, and (b) zero the drive with the vendor diagnostic (lifeguard or seatools).
Your link is not for your NAS, it is for the old SPARC version. Try support first (support.netgear.com), or perhaps mdgm might chime in on the RN100 series procedure.
Note that the procedure you are asking for is NOT in the thread referenced by Ixa.
