Steerpike
Aug 06, 2015Aspirant
RN104 failed disk - how to activate replacement disk
I have an RN104 with 4x2TB drives in X-Raid configuration. 1 drive has been reported as failed, and device is reporting 'Degraded' (but still working). I ordered identical replacement 2TB drive a...
- Aug 06, 2015
If it is doing a resync it will tell you on the volume tab.
Do you have a backup?
It does not sound like it is doing a resync.
If it isn't I would:
1.Upgrade your firmware to 6.2.5
2. If after this update the disk is still inactive, then hot remove it, wait about 10-15 seconds then hot insert it.
Steerpike
Aug 09, 2015Aspirant
OK, I finally bit the bullet and did what previous poster suggested (thanks!) and upgraded to 6.2.5 firmware. As soon as I did that, I saw 'Volume is Degraded; Rebuilding in Progress ...'. So it looks like I'm on my way.
Reason I was SO HESITANT to upgrade is, I had an identical ReadyNAS 104 unit which became totally unstable a few months ago. After weeks and weeks of back and forth with support (installing various beta releases) I just bought a new one, and following advice on the forums I installed 6.2.3-T1721, which was quite solid. So I was not in the mood for another go around.
Anyway - it's predicting about 17 hours to go so I'll just wait it out!
Thanks again.
mdgm-ntgr
Aug 10, 2015NETGEAR Employee Retired
Sounds like a few months ago you ran into an issue addressed by a stability enhancement in 6.2.5.
- SteerpikeAug 12, 2015Aspirant
mdgm wrote:Sounds like a few months ago you ran into an issue addressed by a stability enhancement in 6.2.5.
Hi there mdgm!
Oh no - tonight my RN104 went offline for the first time in months - two or three days after the upgrade to 6.2.5. Unbelievable! The symptoms are very similar - no GUI access, but - for a short while - I could ping it, and now I can't ping it. As you may recall, this device is in a remote location so I'm going to have to have someone pull the plug on it to restart. I guess I'll have to see if this is a one-off coincidence or not. Darn!
I have had someone on site do a hard reset - pull the plug - TWICE and now I can't even ping the device.
The device seems to get stuck in the 'booting' phase. This shows on the screen after 20, 30 minutes.Any thoughts about next steps?
