alekdavis
Apr 05, 2016Aspirant
RN104 freezing during copy. How to troubleshoot?
When I try to copy files from one share to another (on the same NAS device), Windows Explorer hangs and ReadyNAS becomes unresponsive. Copying seems to work for most shares, but always causes issues ...
Apr 05, 2016Guru - Experienced User
If you look in the volume maintence settings, you'll see a disk test option, scrub, balance, and defrag.
Scrub reads all the data in the array, so it is a reasonable test to try first.
alekdavis
Thank you, Stephen. I did not realize there's a clickable icon to get to maintenance options. Doing it now. I appreciate your response.
- Jan 17, 2024Retired_Member
