alekdavis
Apr 05, 2016Aspirant
RN104 freezing during copy. How to troubleshoot?
When I try to copy files from one share to another (on the same NAS device), Windows Explorer hangs and ReadyNAS becomes unresponsive. Copying seems to work for most shares, but always causes issues ...
alekdavis
Apr 07, 2016Aspirant
The scrub process just finished running. How do I know if it encountered errors? I only see these messages in the log:
| Wed Apr 6 2016 22:02:05 | Volume: Scrub completed for volume data'. | |
| Tue Apr 5 2016 18:15:29 | Volume: Scrub started for volume data. |
Also, the problem remains. When I try to copy a file from a share (to a different share on the same volume), it freezes the system.
Apr 07, 2016Guru - Experienced User
If there had been errors, then you would have seen more logging.
-Do you see these freezes when you do the copy from the NAS (for instance a NAS backup job)?
-After you try that, I'd suggest starting a balance.
- alekdavisApr 07, 2016Aspirant
I don't do backups, so can't tell (I back up data from ReadyNAS to the cloud and another NAS). I'll try balancing (haven't done it either).
Here is what I found. If I try to copy from one share to another (on the same volume), it freezes the device. I tried copying via Windows Explorer (drag and drop) and via command line (xcopy). Same result. As soon as I start, it freezes everything (explorer, command prompt, admin page, etc), and I need to unplug the cord. But if I copy from ReadyNAS to a local drive (view Explorer or command line), it works fine. Weird. Don't know if balancing will help, but I'll try it next.
Thank you for the suggestions.
- StephenBApr 07, 2016Guru - Experienced User
I suggest making a test share, and creating a backup job to copy into it from an existing NAS share.
That will take the network out of the equation.
- alekdavisApr 08, 2016Aspirant
Done. The backup ran fine. Not sure if it's a good or bad thing at this point. :-)
- Jan 17, 2024Retired_Member
