alekdavis
Apr 05, 2016Aspirant
RN104 freezing during copy. How to troubleshoot?
When I try to copy files from one share to another (on the same NAS device), Windows Explorer hangs and ReadyNAS becomes unresponsive. Copying seems to work for most shares, but always causes issues ...
ElectricKeet
Apr 18, 2016Tutor
I've been having the exact same issue ever since I purchased the 104. Here's what I know about copying files within the same share:
- From Windows 7's Explorer, any file copy works by dragging the data to the client and then sending it back to the NAS.
- From Windows 8/8.1/10's Explorer, file copies go blisteringly fast regardless of file size, a sure sign of proper copy-on-write behavior. However....
- ...that's only if I copy them one at a time with plenty of opportunity for everything to finish before starting the next file copy. If I copy in a batch (as in, two or more) then the chance of a hang goes up to... well, as far as I can tell, 100%. The copy dialog will show things starting to move, and then usually get to about a sixth of the way in to the process before simply stalling out.
- By "stalling out", I mean, when I SSH in to the thing and do a 'top', it shows smbd chewing up as much of the CPU as it can get, generally 80~98%. This is accompanied by the same lack of ability to do a graceful shutdown of the NAS, ultimately requiring unplugging the sad thing and plugging it back in.
I have gone through a stupendous amount of research, reconfiguration, and time-consuming trial-and-error... but all for naught. I'll keep trying to find some workaround that isn't simply reverting to naive over-the-network copying....
alekdavis
Apr 18, 2016Aspirant
These sounds very similar to what I'm experiencing. Thank you for the feedback, ElectricKeet. I was about to dump the device and buy myself a Synology or QNAP, but I'll hold on to it for now to see if there is something we can do.
- mdgm-ntgrApr 19, 2016NETGEAR Employee Retired
Shortly after encountering the problem can you send in your logs (see the Sending Logs link in my sig) and note roughly the time when the unit froze?
- ElectricKeetApr 19, 2016Tutor
mdgm wrote:Shortly after encountering the problem can you send in your logs (see the Sending Logs link in my sig) and note roughly the time when the unit froze?
Absolutely. I took these steps:
- Cleared the logs.
- Rebooted the RN104 (running firmware 6.4.2, but this has been happening with earlier revisions also.)
- Once accessible, I used Explorer on my Windows 10 laptop to copy (^C) a directory containing 229 files to another directory within the same share. It claimed to get through 20 files before stalling out completely. The time was around 09:36.
- Waited for Windows to give up and toss me an error message. This took several minutes, during which I bumbled around a bit within the ReadyNAS admin page and noticed a few... quirks. We'll get to those a bit later.
- Eventually, Windows popped up a dialog complaining, "Error 0x8007003B: An unexpected network error occurred." I selected "Do this for all current items" and clicked the Cancel button.
- Tried to refresh the view in Explorer. As expected, Explorer stalled trying to get anything from the NAS.
- Pulled the NAS' power cord, plugged it back in, let it boot.
- Through the ReadyNAS admin page, downloaded the logs that I have sent.
Those quirks I mentioned?
- The unit's time is around 15m30s slow. This means that when I say I tried to copy files around 09:36, the NAS thinks it's more like 09:20 or so.
- This is despite having "synchronize time" enabled in the admin page... which, by the way, completely ignores any attempt to change the time servers.
- You know, I could have sworn I told it to clear logs, but there's an awful lot of stuff in those downloaded log files....
- StephenBApr 19, 2016Guru - Experienced User
Usually this happens when the NAS is improperly configured to use a static address. The most common error is to forget to add DNS servers to the configuration, though a wrong subnet mask or gateway address could also do it.
- alekdavisApr 19, 2016Aspirant
Thank you, mdgm. Will do (I assume I need to get the logs after hard-booting the device). I'm not sure if I get this soon, though, since I changed the workflow and don't use NAS that often. In the old workflow, my wife (who is doing lots of photo work) would copy raw image files from an SD card to NAS, and then process them on Photoshop directly on NAS. The device would hang during both copy to NAS from SD card and copy between the NAS shares operations. I told her to process all files locally on the laptop, and I back them up periodically to NAS, so with this workflow we don't seem to see issues (I also managed to move the video files between NAS shares that caused consistent hangin and having done this it looks okay). So at this point with with not as much use of the NAS, it does not cause major issues, but I'll upload the logs when it happens next time. Thanks again for following up. I appreciate it.
- Jan 17, 2024Retired_Member
