77PALE77
Jul 24, 2023Apprentice
RN104 Is manual install of 6.10.9 safe?
Hi everyone, my RN104 says its firmware 6.10.8 is up to date, even if I search for updates no update ion any kind s available; but I know there is a 6.10.9 release. Is it safe to upload it on the N...
Aug 03, 2023Guru - Experienced User
Etarsha wrote:
The firmware version 6.10.8 appears to be causing issues with my installed apps and now I cannot even upgrade to 6.10.9; any other suggestions?
What apps?
Etarsha
Aug 03, 2023Aspirant
Plex, it hasn't let me update the app since I updated the firmware. I get an error code 22007100001; which there was another thread about and I tried all of their actions but nothing worked. Everything currently "works" but I am worried how many updates before things start breaking.
Link to post #https://community.netgear.com/t5/New-ReadyNAS-Users-General/ReadyNAS-212-won-t-upgrade-or-install-apps-Help/td-p/1852922
Additionally I have tried to manually install an older firmware version (6.10.7-arm) and I tried to reinstall 6.10.8-arm to see if that would do anything, both resulted in the unknown server error. Short of combing through he storage and overwriting files, which I do not want to do, I am at a loss.
- StephenBAug 03, 2023Guru - Experienced User
I am puzzled by this, as I did not see this behavior with my RN102 or my RN202.
- NiveditaP3Aug 04, 2023NETGEAR Expert
Hello Etarsha
You can follow these steps manually and try installing the firmware:
1. copy the image to : /root/ReadyNASOS-6.10.9.img
2. and echo /root/ReadyNASOS-6.10.9.img >/etc/.flash_update
3. then reboot, it should install the 6.10.9Have a lovely day,
Nivedita Pa
Netgear Team - StephenBAug 04, 2023Guru - Experienced User
1. copy the image to :/root/ReadyNASOS-6.10.9.img
3. then reboot, it should install the 6.10.9Note this requires ssh to be enabled. If you use these exact steps, then delete /root/ReadyNASOS-6.10.9.img after the reboot. Though you can simplify by just copying the image to /etc/.flash_update
- EtarshaAug 04, 2023Aspirant
Can you confirm that I have to do this through some form of SSH? Using windows explorer, I see no root folder on my NAS even with unhidden files/folders. Must I copy these files over using the cmd or other console like program (like PuTTy)?
- schumakuAug 04, 2023Guru - Experienced User
None of this required .... https://kb.netgear.com/26212/ReadyNAS-OS-6-Updating-Firmware Scroll down to "To locally update ReadyNAS OS 6 firmware via the Admin Page:" FMI.
Desperate to do it "manually" using SSH do as NiveditaP3 advised before. Start with downloading the https://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNASOS-6.10.9-arm.zip to a shared folder like Public, do the unzip there, ...
The issue is the automatic and manual updates from the admin page are failing. So I am trying to find another way to force it to complete and hope that fixes whatever is causing the errors. I really do not want to factory reset the NAS since that also wipes the drives.
Yes, NiveditaP3's procedure requires use of ssh.
- schumakuAug 05, 2023Guru - Experienced User
StephenB wrote:Yes, NiveditaP3's procedure requires use of ssh.
Etarsha following the ssh based update process does not magically cure (most or any) update issues.
Start with a cold reboot to clear out the RAM disk based root file system - I understand, you already tried this. Poor deployments of Apps can easily cause many issues, the "wrong" file systems are easily flooded.
When having a root shell access open, check (and post) the output of mount and df (disk free) for further reference. And no, this does not imply there is a risk or a problem in deploying firmware updates.
- StephenBAug 05, 2023Guru - Experienced User
Etarsha - it is possible that the OS partition is too full to apply the update.
If you don't want to use ssh, you can also check for this by downloading the log zip file from the web ui log page. Open volume.log, and scroll down to the section that starts with === df -h ===
You should see something like this:
=== df -h === Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 3.7G 746M 2.8G 21% / ... === df -i === Filesystem Inodes IUsed IFree IUse% Mounted on udev 63126 437 62689 1% /dev /dev/md0 1048576 14586 1033990 2% / ...The /dev/md0 lines are the OS partition on the disks.
Let us know what these lines show in your logs.
- aks-2Aug 15, 2023Apprentice
I can confirm the following steps worked for me, I have a ReadyNAS 214 and updated it in the last couple of weeks:
- Download ReadyNASOS-6.10.9-arm.zip
- Unzip on my Win10 PC, to get ReadyNASOS-6.10.9-arm.img
- Using Firefox, visit the ReadyNAS dashboard -> settings -> Install Firmware
- Browse to the .img file and select upload
- Reboot the NAS
Do you have any blockers/antivirus on your PC that could be messing up the download?
