rn104
Jul 07, 2015Star
RN104: @mdgm-Benefits of factory reset under firmware v6.2.x
I remember some time back that mdgm mentioned there were advantages to doing a full factory reset on an RN104 when upgrading to v6.2.x versus just a simple firmware upgrade. However the specific advan...
mdgm-ntgr
Jul 07, 2015NETGEAR Employee Retired
In 6.1.5 we changed a setting when creating new volumes. If you last did a factory reset on older firmware than that there certainly would be a benefit to backing up your data, doing a factory default (wipes all data, settings, everything) and restoring your data from backup. But, if you decide not to do a factory reset you'd still be better off on 6.2.5 than you would be on the firmware you are on now.
The change for creating new volumes in 6.1.5 improves stability. You can either backup your data, do the factory reset and restore your data from backup now; or backup your data and if you run into the problem that the factory reset would resolve at that point do the factory reset and restore from backup.
