jrhslick
May 07, 2024Aspirant
rn104 network issue
A returning issue with my NAS is the error of not being able to download anti virus to check network. I am connected to a fibre network through a GB switch. I can get to my NAS unit through any of t...
- May 07, 2024
The RN104 no longer supports antivirus - the feature was removed for RN100 systems in 6.10.0 because the NAS no longer had enough memory to run it.
So you should disable the feature (and consider upgrading your firmware to 6.10.9). 6.10.10 removes the ability to install apps, so if you use them you shouldn't install that one.
May 07, 2024Guru - Experienced User
