DrDSP2
Jun 13, 2021Aspirant
RN104 Stuck in "Connecting to ReadyNAS Admin Page"
ReadyNas was working properly before automatic upgrade to 6.10.5. Afterwards, I'm caught in the "Connecting to ReadyNAS Admin Page" loop when tring to access the admin page. I do have SSH access. ...
- Jun 14, 2021
DrDSP2 wrote:
Tried OS reinstall via the boot menu - this seemed to fix things until I changed the admin password from the default password setting. I can't leave the default password set though.
I'm trying to avoid a Factory Reset... Any ideas?
- Do another OS reinstall.
- Downgrade to 6.10.4 (without changing the password).
- After the downgrade reboot, change the password.
Jun 14, 2021Guru - Experienced User
DrDSP2
Jun 21, 2021Aspirant
Really? So the solution is to abandon the latest update and just stick with the prior release going forward?
Will I ever be able to upgrade again? Is the update bad or just incompatible with the previous one? If incompatible, then it seems poor to automatically upgrade to a version that brakes the http auth process...
Maybe I'll just grit my teeth and perform the factory update.
Thanks,
- SandsharkJun 22, 2021Sensei
That is the work-around if the bug affects you (it doesn't affect everyone) until Netgear publishes a real fix.
