DrDSP2
Jun 13, 2021Aspirant
RN104 Stuck in "Connecting to ReadyNAS Admin Page"
ReadyNas was working properly before automatic upgrade to 6.10.5. Afterwards, I'm caught in the "Connecting to ReadyNAS Admin Page" loop when tring to access the admin page. I do have SSH access. ...
- Jun 14, 2021
DrDSP2 wrote:
Tried OS reinstall via the boot menu - this seemed to fix things until I changed the admin password from the default password setting. I can't leave the default password set though.
I'm trying to avoid a Factory Reset... Any ideas?
- Do another OS reinstall.
- Downgrade to 6.10.4 (without changing the password).
- After the downgrade reboot, change the password.
lynnmonk
Jun 26, 2021Aspirant
I have the same issue. Please can you explain how to downgrade? I've only ever used the upgrade button!
Jun 26, 2021Guru - Experienced User
First, find the zip file for the firmware you want to install. Just google with site:kb.netgear.com in the search string. Note Netgear says you need to stay within the major release number (e.g., you can downgrade to 6.10.x but not back to 6.9.x).
I don't know what you were running before. 6.10.4 has a bug related to "pull" rsync backups, so if you use those you should go back to 6.10.3 If not, 6.10.4 should be fine. Those two are located here:
- https://kb.netgear.com/000061727/ReadyNAS-OS-6-Software-Version-6-10-3
- https://kb.netgear.com/000062588/ReadyNAS-OS-6-Software-Version-6-10-4
Second, you download the firmware zip file for your platform (which in you case is arm).
Third, you extract the firmware image from the zip file (ignoring the release notes). For instance, ReadyNASOS-6.10.4-arm.img If you don't have a zip software package, 7-zip is a good free one for Windows. I don't use a Mac, but there are also free zip utilities available for it (izip being one).
The manual install is on the system->settings->update in the admin web ui - you click on the "manual update" control, and just follow the prompts.
If you can't log in at present, then start by browsing to https://nas-ip-address/admin (spelling out https, and of course using the real IP address of the NAS). If that doesn't work, then you'll need to do an OS reinstall from the front panel. Let us know either way (it'd be good to know if the https:// workaround works for you).
