maxman1
Mar 23, 2018Apprentice
RN104 stuck on Booting after firmware upgrade
3 Days ago I installed firmware 6.9.3 on my RN104. I was in the other room. After about an hour on not being able to access my NAS, I went and saw on the LCD "Boot from USB Failed!". So thanks so muc...
- Mar 26, 2018
I just spent a couple hours completely taking the NAS apart, cleaned, put back together. It wasn't very dusty, and the backup button did not appear stuck. However, I put it all back together, and surprisingly it seems to be working fine now. :)
maxman1
Mar 26, 2018Apprentice
- DamionJonesApr 02, 2018Aspirant
For what it is worth, this past week, I have been moving everything from my NAS Boxes to my Server.
I have 2 ReadyNAS 104 boxes, both with 4x3TB Drives in ( all WD RED ) plus I alos have 2 DLINK 320B NAS Boxes, bothwith 2x2TB in, one with Hitachi and the other with Seagate.
The Netgears were both setup with 2x3TB as one in RAID and the other 2 as seperates. Now, they are simply going to be acting as backup to the Server's DATA Drives.
Now, when I reset my first NAS, it went through just fine and I was ok with it, however the second one seemed to be trapped like yours, in some infinite loop? I reset it a few times, ( I think 3 times? ) and it finally got itself all sorted out.
I dont know why this was, but I do know, that even though both my Netgear 104's are completely empty, and I have them setup both as one single drive in RAID5, they are in a RE-SYNCING sort of loop now, that is getting on my nerves...
Whats it SYNCing with? And why is it taking days to SYNC with nothing?
Is yours now doing that?- mdgm-ntgrApr 02, 2018NETGEAR Employee Retired
The disks have to be synced sector by sector to setup the RAID. This is done at a lower level than the filesystem.
- maxman1Apr 02, 2018ApprenticeNo, mine is working normally. I'm not seeing the sync loop you are seeing.
I don't think I can help, my only suggestion is to check your apps and any backup jobs you might have.. Perhaps there is an app trying to sync and failing or a backup job failing (and keeps retrying )- StephenBApr 02, 2018Guru - Experienced User
maxman1 wrote:
I don't think I can help, my only suggestion is to check your apps and any backup jobs you might have.. Perhaps there is an app trying to sync and failing or a backup job failing (and keeps retrying )I don't think so- this sounds like a normal RAID resync. It takes a long time to complete on an RN104. The OP uses the word "loop", but doesn't explain why he thinks it is looping.
