maxman1
Mar 23, 2018Apprentice
RN104 stuck on Booting after firmware upgrade
3 Days ago I installed firmware 6.9.3 on my RN104. I was in the other room. After about an hour on not being able to access my NAS, I went and saw on the LCD "Boot from USB Failed!". So thanks so muc...
- Mar 26, 2018
I just spent a couple hours completely taking the NAS apart, cleaned, put back together. It wasn't very dusty, and the backup button did not appear stuck. However, I put it all back together, and surprisingly it seems to be working fine now. :)
maxman1
Mar 26, 2018Apprentice
DamionJones
Apr 02, 2018Aspirant
For what it is worth, this past week, I have been moving everything from my NAS Boxes to my Server.
I have 2 ReadyNAS 104 boxes, both with 4x3TB Drives in ( all WD RED ) plus I alos have 2 DLINK 320B NAS Boxes, bothwith 2x2TB in, one with Hitachi and the other with Seagate.
The Netgears were both setup with 2x3TB as one in RAID and the other 2 as seperates. Now, they are simply going to be acting as backup to the Server's DATA Drives.
Now, when I reset my first NAS, it went through just fine and I was ok with it, however the second one seemed to be trapped like yours, in some infinite loop? I reset it a few times, ( I think 3 times? ) and it finally got itself all sorted out.
I dont know why this was, but I do know, that even though both my Netgear 104's are completely empty, and I have them setup both as one single drive in RAID5, they are in a RE-SYNCING sort of loop now, that is getting on my nerves...
Whats it SYNCing with? And why is it taking days to SYNC with nothing?
Is yours now doing that?
- mdgm-ntgrApr 02, 2018NETGEAR Employee Retired
The disks have to be synced sector by sector to setup the RAID. This is done at a lower level than the filesystem.
- maxman1Apr 02, 2018ApprenticeNo, mine is working normally. I'm not seeing the sync loop you are seeing.
I don't think I can help, my only suggestion is to check your apps and any backup jobs you might have.. Perhaps there is an app trying to sync and failing or a backup job failing (and keeps retrying )- StephenBApr 02, 2018Guru - Experienced User
maxman1 wrote:
I don't think I can help, my only suggestion is to check your apps and any backup jobs you might have.. Perhaps there is an app trying to sync and failing or a backup job failing (and keeps retrying )I don't think so- this sounds like a normal RAID resync. It takes a long time to complete on an RN104. The OP uses the word "loop", but doesn't explain why he thinks it is looping.
- DamionJonesApr 03, 2018Aspirant
RE: Looping
When you said OP, did you mean me? I did say that it was in a sort of loop, but of course I know its not as the % is definitely going up... I merely meant that not litterally.
The whole thing is horribly slow, dropping down to 10mb/s and at best its at 40.
And yes, I agree that it is the normal RAID RESYNC but it seems to be rather slow, but as has been suggested, the 104 is slow at that, and so there is the answer there then!
My only one issue now, is that they are now just being buggers to me in their visibility.
For example, my AMD can see them perfectly fine, and always has.
My Kabylake however sees them, I can access the main admin page, but can I get at the files? NO! - I can use the download option from inside the admin page yes, but I cannot simply make a Network drive or even go through the network with explorer.
This has been a pain for a few weeks and it sort of does it on and off on other Machines too... That is why I decided to stop using them and move everything to the SERVER.
The DLINKS are doing the exact opposite... They are seen in the Intel but the AMD does not.
My daughters PC sees everything and my sons sees nothing and the Media PC also has issues, but they all see the server, so...
