pandyarajen
Jul 15, 2015Aspirant
RN104 unresponsive
Hello, I am a new user. I own RN104. FW 6.2.4. Since last few days the NAS was behaving weird. I don't recall when I upgraded the FW. Everyday evening ReadyNas will not be accessible. Not able ...
mdgm-ntgr
Jul 15, 2015NETGEAR Employee Retired
When you say it did not turn on, what happens? Do any of the lights come on? Does the fan come on? Does the LCD come on? Or is there no response at all?
If the NAS is getting stuck booting then it would be better to troubleshoot it with the drives in the unit they are in now.
Do note as Nhellie mentioned that the firmware is installed onto the disks. So if the problem is with the OS on the disks it will remain when you move the disks to a new chassis.
I would use a scratch disk (must not be from your array) to update the other 104 to 6.2.4 or 6.2.5-RC1 before powering down, removing the scratch disk and moving the disks across (keep the order the same) if you really want to try moving the disks to a new unit.
