pdasterly
Dec 30, 2015Guide
rn104 wont shutdown
Nas wont shutdown via shutdown in admin page or manual shutdown by pressing power button on device several times. Device shutsdown but then reboots itself
- Dec 30, 2015
If you disable WOL are you still unable to shutdown?
mdgm-ntgr
Dec 30, 2015NETGEAR Employee Retired
Are you using the power timer or WOL?
Which firmware are you running?
Can you send in your logs (see the Sending Logs link in my sig)?
