_63er's avatar
_63er
RN10400 Error do_exit+8ec
Hello,
my readynas rn104 is starting with error "do_exit+8ec" beetween updated to 6.6.0. I follow the instructions to usb recovery.
After I booted from USB shows me the display "ReadyNAS USB Recovery". I wait 1 hour and nothing happens more ... how long can the recovery last?
greets
     chris
  • Now that I've had a look it and fixed some things it looks like your system has come up fine now, but there are still a few more things that need fixing.
    I have sent you another PM.
  • waiting over 2 hours with the USB Recovery :(
    OK! I Think my data lost :(
    Chris
    • mdgm-ntgr's avatar
      mdgm-ntgr
      NETGEAR Employee Retired
      mdgm-ntgr
      This error doesn't indicate any problem with your data. Your data is probably fine.
      Can you try USB Boot Recovery with 6.6.1 beta?
      Also note you may need to use multiple different USB keys before you find one that works.
      I'll send you a PM with some additional suggestions.
ProSupport for Business
