pcsentinel
Oct 08, 2021Aspirant
RN10400 Nas Station starts for 1 second then turns off then starts again for 1 second continuosly
Hi, the power button and power light come on and the diplay shows an intial screen with NETGEAR STORAGE welcome, but then after a second they all turn off again, then after a few seconds that the cyc...
- Oct 08, 2021
Most likely a power problem. Booting without drives may help determine that. If it is that, then the next step would be trying another power brick.
Oct 08, 2021Guru - Experienced User
Try removing the disks (labeling by slot number), and then power up again. See if it gives you a "no disks" status.
Sandshark
Oct 08, 2021Sensei
- pcsentinelOct 22, 2021Aspirant
Thanks, yes with all drives removed then it started. I measured the pins on the the power supply output and only one was showing 12V. I purchased a new PS and everything works again.
