Andrew_Oz's avatar
Andrew_Oz
RN10400 Power supply failure - flashing green light
Hi,
My power supply has failed - the green light flashes about once per second and the NAS powers up for that split second and then goes off again. I suspect it's the power supply. It has a special connection at the NAS end so I'm guessing I can't easily by one from an electrical dealer.
Do Netgear have spare parts which I can purchase or does anyone have a spare one I can buy from them?
Thanks
Andrew
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Andrew_Oz
    Welcome to the Community!
    If it's the adapter you need you can purchase a 4-PIN DIN AC Adapter (12V, 7A External 90W; input 100-240V AC, 50-60Hz) on Amazon or other online stores.
    If it's the Internal Power Supply on the RN104 spare parts are not available from NETGEAR, the best thing to do would be to purchase a refurbished RN104 online or upgrade to a newer NAS if possible. If your RN104 was purchased under 3 years RMA can be provided to you. You just need to register it at my.netgear.com and create a case.
    You will also have to provide the Proof of Purchase upon requesting for RMA.
    HTH
    Regards
ProSupport for Business
