Dalo-Harkin
Jan 25, 2019Aspirant
RN204 issues with 1 disk
Hi All,
My RN204 has been workign perfectly for well over 5 years so I was long overdue a problem ha ha
A little extra info:-
Disk 1 - 2TB
Disk 2 - 2TB
Disk 3 - 3TB
Disk 4 - 2TB
All in X RAID (RAID 5)
around 2.5TB free space left, 23GB of snapshots
After I upgraded the firmware to 6.2.5 latest the other day (coincidence I think) I started to get a lot of AAT errors on Disk 3.
I removed the disk and tried to put a 1TB in its place but it came up with the flashing data degraded and kept doing so and did not even try and add the new 1TB disk into the pool.
I put the original 3TB disk back in, and it started to recover data (albeit very slowly) 5% in 24 hours.
So my question is, once it has recoved all data, should I be able to just add a 2TB drive (looking at the free space above of 2.5TB) I should have around 500GB of spare space?
Thank you in advance for any help
XRAID won't shrink an array, it will only expand one.
So you can't replace a 3 TB drive with anything smaller.
- Dalo-HarkinAspirantHi and thanks for posting, even if there is 2.5TB free space across all 4 disks?
- SandsharkSensei
Actually, since only 2TB of the 3TB is actually in use, the array doesn't need to shrink and I believe you can replace it with a 2TB. I think I did that experiment back when I got my last new NAS and tried out a lot of stuff. Unfortunately, I'm not sure enough to recommend you buy a 2TB to use. But if you already have the 2TB, then do try it and let us know what happened.
