BBSUP
Oct 14, 2020Aspirant
RN212 volume degraded after reboot after replacing disk
Set-up: Raid1 (X-RAID), 2 x WD Nas Red 2TB disks On 20 August the volume status changed to degraded. Only 1 disk visible anymore. Due to circumstances the disk was only replaced on 12 October. A...
BBSUP
You can download the log zip file. Disk-info.log might give you some info, though generally "dead" disks aren't listed there. You can also look for i/o errors in system.log and kernel.log.
Disk-info.log: only active disk
System.log: nothing relevant afaics
Kernel.log: a whole bunch of errors. I copy/pasted some in a previous post, but this seems to have disappeared. Moderator, please release that post :smileywink:
Oct 14, 2020Guru - Experienced User
And they do look like interface errors.
The safest way to test if this is the chassis is by inserting a scratch disk into that bay (by itself) and try a factory install. That eliminates the chance of data loss.
