Hillel1022
Nov 15, 2019Follower
RN21200-100NES
My device is formating two brand new 6TB drives and the blue power diode is flashing.How many hours to complete formatting?
Sandshark
Nov 15, 2019Sensei
Hopefully, you mean it's doing a RAID sync. Formatting should only take a few minutes.
RAID1 sync on the ReadyNAS takes way longer than it should. You should expect something in the 30+ hour range. You should, however, be able to log into the NAS and see the progress on the Volumes page. If you can't, then there may be a problem with one of your drives.
