firefox111
Oct 24, 2016Apprentice
RN21200 and GS116E-200NAS switch
Hello. Firmware version is 6.6.0. Does the Netgear GS116E-200NAS switch support "IEEE 802.3ad LACP" mode on the ReadyNAS network interface bonding?
Thanks in advance.
- mdgm-ntgrNETGEAR Employee Retired
The GS116E-200 switch supports manual static LAG (see datasheet).
You should consider getting a SMART switch for use with LACP.- DaneANETGEAR Employee Retired
Hi firefox111,
As a follow-up on mdgm's response, kindly check the link below for a variety of standalone NETGEAR Smart switch models you could choose from:
NETGEAR Standalone Smart Switch Series
DaneA
NETGEAR Community Team
DaneA wrote:
...check the link below for a variety of standalone NETGEAR Smart switch models you could choose from:
You'd want a GS model (gigabit) of course. With LACP its best to get a switch with enough ports so that you can connect all your wired devices to the same switch.
