Zurd
Jul 27, 2020Star
RN214 - Extremely slow with zip files
Hi, I have a ReadyNAS 214 and it used to be fine before but since about 6-8 months or so, it is extremely painfully slow to compress / decompress zip files. Is it normal? Why would it be so slow? Any...
Jul 28, 2020Guru - Experienced User
It's not something I do much. My setup is different (a 526x NAS using a 10gbit network - and no encryption). If I have a chance, I'll try to duplicate your results on a Windows PC and see how that compares. I use 7-zip (not sure if that will make a difference or not).
- StephenBJul 28, 2020Guru - Experienced User
Turns out the 7-zip command line interface is a bit restrictive - it won't allow me to put an output zip on the SSD when the source is on the NAS.
However, I was able to compare SSD->SSD performance on my PC with NAS->NAS performance using a mapped drive on the PC. While the NAS->NAS performance was slower, it wasn't anything like what you are seeing. My test folder has 5884 files in 177 folders, and a total size of about 500 MB.
I suggest trying your test w/o the round-robin bonding - just to see if that is a factor. You could also try to duplicate my results with 7za.
Local SSD->Local SSD Zip Creation took about 12 seconds (Global Time is the actual wall clock time).
Test1: Create Zip SSD->SSD 7za a -bt -tzip LocalTestSrc Files read from disk: 5884 Archive size: 297220124 bytes (284 MiB) Everything is Ok Kernel Time = 1.968 = 16% 132515 MCycles User Time = 38.171 = 325% Process Time = 40.140 = 342% Virtual Memory = 150 MB Global Time = 11.722 = 100% Physical Memory = 90 MB
NAS->NAS Zip creation took about 40 seconds - definitely longer, but not minute/hours.
Test2: Create Zip NAS->NAS (526x mapped drive) 7za a -bt -tzip NASTestSrc Files read from disk: 5884 Archive size: 297195876 bytes (284 MiB) Everything is Ok Kernel Time = 4.593 = 11% 146766 MCycles User Time = 39.234 = 99% Process Time = 43.828 = 111% Virtual Memory = 150 MB Global Time = 39.332 = 100% Physical Memory = 48 MB
FWIW, the process time and cycle count is really quite close. I'm guessing the difference is SMB latency.
Local SSD-SSD extraction also took about 12 seconds:
Test3: Extract ZIP SSD->SSD 7za x -bt -tzip LocalTestSrc.zip Folders: 178 Files: 5884 Size: 486495926 Compressed: 297220124 Kernel Time = 6.875 = 58% 35717 MCycles User Time = 3.843 = 32% Process Time = 10.718 = 91% Virtual Memory = 5 MB Global Time = 11.736 = 100% Physical Memory = 9 MB
NAS->NAS extraction took about 80 seconds
Test4: Extract ZIP NAS->NAS (526x mapped drive) 7za x -bt -tzip NASTestSrc.zip Folders: 178 Files: 5884 Size: 486495926 Compressed: 297195876 Kernel Time = 14.796 = 18% 62914 MCycles User Time = 3.453 = 4% Process Time = 18.250 = 23% Virtual Memory = 5 MB Global Time = 78.821 = 100% Physical Memory = 9 MB
Process time and cycle counts are higher than the local extraction test, but I think the main difference is again SMB latency.
I then repeated the NAS->NAS tests on an RN202. I'm not using bonding (and I don't use volume encryption). The share is on a jbod volume.
The NAS->NAS zip creation results were similar to the RN526 performance. The extraction test was quite a bit worse (165 seconds, compared with 79). Still not minutes/hours though.
- SandsharkJul 28, 2020Sensei
Total guess, but try disabling strict sync on the share. That causes Veracrypt to slow to a crawl on writes, and this may be related. If you are running SMB Plus and have enabled pre-allocation, you should also try disabling that.
- StephenBJul 29, 2020Guru - Experienced User
Strict sync was enabled in my measurements, so that isn't it.
I don't see how pre-allocation would affect extraction to the local PC hard drive, since the NAS is only being read.
Could the zip file (or the share) be heavily fragmented?
How full is the volume?
