OleGyldenloeve
Jan 12, 2020Aspirant
RN214 invalid password after firmware 6.10.2
After installing firmware 6.10.2 from the admin browser interface NAS rebooted as expexted. After reboot NAS will not accept my usual password. Apearently, password reset has not been set on my devic...
- Jan 12, 2020
Does your password include any unusual characters? I'm not specifically aware of any new restrictions, but maybe one of the Netgear mods is.
Did you try the default password password? Maybe it somehow did an OS re-install instead of just an update.
OS re-install from the boot menu will reset your admin password to the default. It will also change IP allocation to DHCP if you had a static IP address. Just be sure not to accidently do the Factory Default, as that wipes your data.
Sandshark
Jan 12, 2020Sensei
- OleGyldenloeveJan 12, 2020Aspirant
Thanks for your reply, Sandshark. My password contains numbers only. I have tried both the password password and admin with no luck. I think maybe I will have to try with OS re-install from boot menu.
- strykerozJan 15, 2020Tutor
Thanks for this. I was having the same issue. Reinstalling OS was quick, and reset the admin password to password and now I'm back in the game. Thanks!
