DarkSideRC
Aug 20, 2022Aspirant
RN214 Reset to factory default stuck at 65% since 8h
RN214 with 2x 4tb HDD Seagate, RAID 1 After an electricity shutdown, my NAS can't reboot. I made an image the disks and I save my data with ReclaiMe File Recovery on a valid Disk Then i ...
Sandshark
Aug 20, 2022Sensei
No, it's not normal that it gets stuck and 2 4TB drives should take more than a few hours to sync. It sounds as if one of the drives has errors.
DarkSideRC
What is the best way to solve this ?
- StephenBAug 20, 2022Guru - Experienced User
I suggest testing the disks with Seatools in a Windows PC.
- DarkSideRCAug 20, 2022Aspirant
Thanks a lot for advice. Iwill try 🙂
- DarkSideRCAug 24, 2022Aspirant
Well, that's not disks...
I use Seatools to check disk and they are ok
I then try new disks (same ref than old ones that former work well with the NAS)... same problem :
Reboot in restore mode, got to 67% in a few minutes then stuck there, hearing disks working (now they are stuck for 27h).
Another idea ?
