Per_Hallenborg
Jun 15, 2018Aspirant
RN3100 SNMP monitor of APC UPS
Fellow experts!
Scenario:
Model: ReadyNAS 3100 V2
FW: RAIDiator 4.2.31
UPS: APC Smart-UPS X 3000 network connected UPS, latest FW
SNMP v1
I am trying to SNMP monitor the UPS over ...
Marc_V
Jun 17, 2018NETGEAR Employee Retired
Welcome to the Community!
The NAS you are using uses an older version of NUT but the APC model you have is listed on it's compatible devices. You may check here.
It mentioned that the APC models SMX does need to use the AP9620 SmartSlot expansion card and smart cable. Check here.
Regards
Per_Hallenborg
Jun 19, 2018Aspirant
Hello.
Thanks for the reply. However it raises another question.
Does it means that it is only possible to monitor the UPS via cable, not SNMP?
Rgds
Per
- Marc_VJun 20, 2018NETGEAR Employee Retired
I am not familiar with APC models but according to APC the SMX model should use the expansion card and cable. http://www.apc.com/us/en/faqs/FA156172/
It needs the expansion card and cable for it to be managed and it's management software.
Regards
