sfpegasus
May 31, 2017Tutor
RN312 major problems after 6.7.4 - will not boot.
Yesterday upgraded to 6.7.4. upgrade apeared to install ok. Messages arriving via email as expected. Last message received was at 9pm "The system is shutting down." System restarted on its own this ...
- Jun 01, 2017
Fixed. Put a good copy of the firmware on the internal flash.
sfpegasus
Jun 01, 2017Tutor
Thanks again. PM replied and awaiting further instruction.
mdgm-ntgr
Jun 01, 2017NETGEAR Employee Retired
- sfpegasusJun 01, 2017Tutor
I cannot thank mdgm enough for the efficient solution to this problem.
Your dedication to this forum is awesome.
- ikonukJun 02, 2017Guide
Indeed! Thanks to mdgm!
Makes it worthwhile to stick to my Netgear NAS.
I. Konuk
- Rich_1Jun 21, 2017Aspirant
Had the exact same problem on Monday morning. Found a solution earlier today. Used Rufus to format the USB for recovery. Now back to normal. The people at the call center are very pleasant but should update their scripts. Would have been back up Monday afternoon if I had read the right post sooner.
