filipinasdelta
Aug 06, 2017Aspirant
RN312 Volume: The resync operation finished on volume data. However, the volume is still degraded
I have this RN312 with 2x4TB WD Red Drives (WDC WD40EFRX-68WT0N0) on RAID 1 at a client and Disk 2 went down so I replaced it with another identical brand new disk. Resync started then completed 4 h...
- Aug 07, 2017
Per mdstat.log, the second disk ends up set as a spare. I'm not sure why that is - the fastest way to resolve it might be netgear support. If the customer purchased between 1 June 2014 and 31 May 2016, then they are entitled to lifetime chat support.
FWIW, the first disk has a couple of errors (2 pending sectors)
Aug 07, 2017Guru - Experienced User
filipinasdelta
Aug 08, 2017Aspirant
Thank you StephenB I'll try getting hold of them.
I'm I wrong to assume it's fine to leave Disk 1 as it is until an eventual fail?
Cheers,
Fil
- StephenBAug 09, 2017Guru - Experienced User
I wouldn't touch disk 1 right now. If you don't have a full backup, I do recommend making one.
