morelor
Aug 08, 2017Aspirant
RN31200 - 6.7.5 - Management service is offline
Data stored on our RN31200 has become inaccessible. Upon using RAIDar, I see that the "Management service is offline". I have tried the following in this order: Restart Reinstall OS Upgrade fi...
JennC
Aug 09, 2017NETGEAR Employee Retired
Hello morelor,
Did you use admin for username and password for password after OS reinstall?
You may also try clearing browser cache the reopen the web browser. Also, unplug one of the LAN cables.
- JennCAug 10, 2017NETGEAR Employee Retired
Hello morelor,
Have you already tried on another computer?
- Cliff_MIAug 10, 2017Guide
I have a ReadyNAS Pro 2 with 6.7.5
I am having the same issue. I have tried all the same things.
I had lost a hard drive and decided to do a factory reset to remove the RAID array. After I did that, I have had this issue.
I have taken out the hard drive and reformated it to complete wipe them. I also used an spare drive just to see if it would install.
When I did this I was told that the drives were dirty and I need to format them again. I did that via Raidar.
Now all I get is the button for offline set up (in Raidar). I can't pull logs or ssh into the nas anymore (factory reset) That does not work. Just get a none responsive web page.
I even tried the USB install and that did not seem to do anything. All I have now is a NAS with blinking blue light.
Any other ideas?
Thanks
- morelorAug 11, 2017Aspirant
Here is the latest update on situation. I can logon to the NAS via ssh and the web admin page is responding now, however, it won't accept my credentials.
Does the web admin page use different credentials than ssh?
Thanks!
- StephenBAug 11, 2017Guru - Experienced User
With SSH you are supposed to log in as root, though it will accept admin.
Root and admin both use the same password (and there is only one admin account, so the web ui also uses that password). Note you do need to log into the web ui as admin.
- Jun 10, 2022Retired_Member
