morelor
Aug 08, 2017Aspirant
RN31200 - 6.7.5 - Management service is offline
Data stored on our RN31200 has become inaccessible. Upon using RAIDar, I see that the "Management service is offline". I have tried the following in this order: Restart Reinstall OS Upgrade fi...
Aug 09, 2017Guru - Experienced User
Do you have a backup of the data?
morelor
Aug 09, 2017Aspirant
StephenB,
Unfortunately, I do not... :smileysad:
JennC,
I've tried admin for username and password for password after OS reinstall, but I haven't had any luck.
- StephenBAug 09, 2017Guru - Experienced User
Are you still able to access the NAS data with SMB (for instance, entering \\192.168.1.50 in windows file manager)?
Also, what is the purpose of the second ethernet connection (192.168.1.207)? Is it connected to a different network?
Also, does https://192.168.1.50/fwbroker respond?
- morelorAug 09, 2017Aspirant
I am unable to access NAS data with SMB. Also, https://<NAS_IP>/fwbroker does not respond.
I have disconnected, the secondary interface. It was connected purely for redundancy.
- StephenBAug 10, 2017Guru - Experienced User
You might need paid support (my.netear.com) for this.
Though if you have a backup, you could do a factory reset and rebuild the NAS (which will destroy any data on it).
- Jun 10, 2022Retired_Member
