CMDIT
Sep 07, 2021Aspirant
RN3138 (fw 6.10.5) - became unresponsive after enabling sleep hard drive during inactivity feature
After enabling the "sleep hard drive during inactivity feature" the unit stopped responding, web page does not work, cannot ping IP addresses, Raidar does not detect it. The unit responds normally with no drives inserted or other drives inserted. The OS reinstall feature and firmware reinstall do not resolve the issue. A factory default will resolve the issue but we need to maintain the data on the unit. This seems to be a bug with firmware 6.10.5.
Is there a way change this setting or revert to a previous firmware usnig the tech debug option?
CMDIT wrote:
After enabling the "sleep hard drive during inactivity feature" the unit stopped responding, This seems to be a bug with firmware 6.10.5.
FWIW, I do use that option with 6.10.5 hotfix 1 and have no issue with it. Though I do not have an RN3138.
Firmware can be downgraded in tech support mode - but I think the first step is to see if you can boot up into tech support mode, and log into the NAS.
- CMDITAspirant
Yes, I am able to get into tech support mode, is there a way to disable that feature there? If not, how do I revert to a previous firmware?
Likely there is, but I am not certain what it is. You might list /etc/hdparm.conf and see if it is in there.
I haven't needed to do this myself, but I believe you first copy the firmware .img file to /root and then do
echo /root/name_of_image_file > /etc/.flash_update
Then reboot the NAS (the reboot command should work).
