ahayes57
Nov 05, 2017Tutor
RN314 - Bond interface bond offline.
Hi,
I've been getting error messages from my NAS telling me the following:
Bond interface bond0 has slave interface eth0 offline.
Bond interface bond0 has slave interface eth1 offline.
I am not sure what is behind this and if it is something i should be concerned about?
I am on firmware 6.9.0 and have my network cards bonded with 'Adaptive Load Balancing' using DHCP etc...
The NAS is still accessible and this appears to be an intermittent fault as I can still access the device and also have no trouble accessing my media from PLEX either but don't want to simply ignore this as I've got half my life backed up on this device...
Any advice or information is most welcome...
I am trying to avoid making any changes such as removing the bond and re-enabling it unless I have to.
Adrian
- grindstrGuide
Hi!
I get exactly the same messages. Can't see any problem and everything seems to work ok. There is no message telling this has been a temperary problem.
grindstr
Sun Nov 5 2017 3:18:44 System: Bond interface bond0 has slave interface eth0 offline. I get the exactly same message. Seems to be related to the 6.9.0 upgrade as I never got this before the upgrade. Nothing else has changed in my setup:
Sun Nov 5 2017 4:16:25 System: Bond interface bond0 has slave interface eth1 offline
- ahayes57Tutor
I've been on to technical with a web chat and they also believe this could be a firmware issue relating to the most recent upgrade to 6.9.0 as the most likely candidate... I am just going throught the motions of submitting logs etc...
- evan2NETGEAR Expert
The issue is fixed on 6.9.1-T119,
Please see below topic,
You may download 6.9.1-T119 from here, https://www.readynas.com/download/beta/readynasos/6.9.1/ReadyNASOS-6.9.1-T119-x86_64.img
- QCC-Math_DeptAspirant
We have actually just recently seen the same issue Bond interface bond0 has slave eth1 offline, and we have already moved up to firmware version 6.9.1 which it looks by this thread is supposed to have resolved this issue. Is there anything we can do to regain this connection?
